Configure the resource usage counters to query the number of ingress and egress IP multicast streams traversing the switch.
This procedure is supported only on a DvR Controller. It is not supported on a DvR Leaf node.
After you configure the counter thresholds for ingress and egress records, if the record usage exceeds the threshold, you receive notification by a trap on the console, a logged message, or both.
If you do not configure the thresholds, the system displays only the ingress and egress records currently in use.
You can configure the resource usage counter on a VRF instance the same way you configure the Global Router except that you must use VRF Router Configuration mode.
Configure the egress threshold to 200.
Switch:1(config)# ip mroute resource-usage egress-threshold 200
Configure the ingress threshold to 100.
Switch:1(config)# ip mroute resource-usage ingress-threshold 100
Enable the log message notification method.
Switch:1(config)# ip mroute resource-usage log-msg
Variable definitions
Use the data in the following table to use the ip mroute resource-usage command.
Variable |
Value |
egress-threshold <0–32767> |
Configures the egress record threshold (S,G). The system sends a notification message after the number of streams exceeds a threshold level. To configure this option to the default value, use the default operator with the command. The default is 0. |
ingress-threshold <0–32767> |
Configures the ingress record threshold. The system sends a notification message after the number of streams exceeds a threshold level. To configure this option to the default value, use the default operator with the command. The default is 0. |
